X15 2450 low power - Printable Version
+--- Thread: X15 2450 low power (/showthread.php?tid=10485)
X15 2450 low power - migueljc - 01-25-2026
hello everyone. I own a Peterbilt 22 x15 CPL5770 serial 80356908 I’m experiencing lost power and high fuel consume 5 mpg no codes no mechanical issues I suspect bad ECM any suggestions or mechanics interested on work in
RE: X15 2450 low power - tree98 - 01-25-2026
Poor fuel mileage and loss of power is extremely broad. Can you give us more details? What is the max boost in a hard pull?
When is the last time you did an EGR tuneup?
Has it had any work done to it ? New injectors installed?
Is it stock or demandated? If it's demandated you need to copy the file out and send it to Rawze for review.
RE: X15 2450 low power - migueljc - 01-25-2026
max boost around 28 I tink it is low. no recently jobs or injectors i recently bought this truck.
Did you buy it in this condition or has it declined since you bought it?
Is it demandated?
it have been getting worse. it’s stock. I bought from a big fleet I’m the second owner. I have noted when it lost power Iost power I have to pull out after re star the engine it improves performance a little bit unless to run at 65 mph
Do an EGR tuneup and see if it improves. The cans probably need baked too. How many miles are on it?
Currently 450k miles on it.
The DPF filters have been cleaned by the dealer before I bought it. KW declares.
RE: X15 2450 low power - Rawze - 01-25-2026
(01-25-2026 )migueljc Wrote:  Currently 450k miles on it.
that does not mean much of anything. They only do that so it does not fault out during a test drive.
DO an EGR tune-up... replace all related sensors, etc. .... The steakers$its are not about to do any of that.
info: https://rawze.com/forums/showthread.php?tid=842&pid=7030#pid7030
I’m going to do the egr tune up.
I have replaced the map and exhaust gas pressure sensor already
