3cyl fuel transfer pump leaking fuel - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: 3cyl fuel transfer pump leaking fuel (/showthread.php?tid=1052) |
3cyl fuel transfer pump leaking fuel - joed2323 - 10-25-2016 2012 isx15, Doing a fuel psi test because fuel was present around the fuel pump, needless to say it failed the test and had fuel running out of head. My question is what all do I need besides the 2cyl fuel pump? Is their a kit with everything I need when I buy the fuel pump part#4307527 Guessing air compressor has to come out to have room? So air comp gasket, also do I need to replace anything else like the fuel rail assembly? Im pretty sure this fuel pump didnt poop out ceramic plungers, so I shouldn't need fuel rail assembly. Do i need to purchase the fuel lines that need to be converted over to 2yl fuel pump? RE: 3cyl fuel transfer pump leaking fuel - jimeneztrans84 - 10-25-2016 U need fuel lines for new 2 cylinder pump. Service bulletin number 110064 has the parts you need RE: 3cyl fuel transfer pump leaking fuel - joed2323 - 10-25-2016 Wow. Price is over 3k on this service bulletin. Parts are ordered. Someone told me the fuel pump has to be timed?? If so what is the procedure for this? Thanks |
