| mx 13 2012 aircompressor - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: CAT, Detroit, and Other engine related Help... (/forumdisplay.php?fid=72) +--- Thread: mx 13 2012 aircompressor (/showthread.php?tid=10520) |
mx 13 2012 aircompressor - Paulywantsacracker - 02-18-2026 i discovered the power steering pump weeping while diagnosing a no start or fuel system loosing prime , was about to mount a new p/s pump with new lift pump when noticed the air compressor bearing failed ,filings and metal in oil , so whats next ? around the farm truck creeping up to 1 mil kms RE: mx 13 2012 aircompressor - marek4792 - 02-18-2026 Replace it. A bad/failing compressor can very easily take out the engine.. RE: mx 13 2012 aircompressor - Paulywantsacracker - 02-18-2026 (02-18-2026 )marek4792 Wrote: Replace it. A bad/failing compressor can very easily take out the engine.. well yes im replacing the compressor and will take off oil pan and clean but what else is neccesary RE: mx 13 2012 aircompressor - marek4792 - 02-18-2026 Rawze Wrote:Now the engine has to come all apart, the oil pan is full of metal shavings, the oil pump is destroyed, the oil cooler full of metal, the oil thermostat full of metal, the filter bypass valve full of metal. The rod and main bearings will need to be replaced and a LOT OF DIFFICULT flushing of the entire oil flow passages through the entire engine have to be cleaned...-- WHAT A MESS!!!- A lot of the engine will have to be pulled apart to clean out this debris because of that failed pump!.reference: https://rawze.com/forums/showthread.php?tid=1805&pid=15389 Someone just mentioned this post in another thread. Although it's mainly referring to fuel pump failure the same principle applies to flushing metal shavings out of the engine. and more info on flushing engine out: https://rawze.com/forums/showthread.php?tid=1805&pid=16203#pid16203 |
