| High Air Filter Restriction - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Pete & KW related Help... (/forumdisplay.php?fid=70) +--- Thread: High Air Filter Restriction (/showthread.php?tid=10528) |
High Air Filter Restriction - Hunter013 - 03-04-2026 2025 T880 X15 Driver said inlet air restriction was at 30 when loaded. We changed the filter (Filter was barely dirty and was changed 1 month before that). Driver said restriction was better, but still high around 17. We took apart whole inlet side and didn't see anything abnormal. What else should we check? RE: High Air Filter Restriction - Rawze - 03-04-2026 Better quality filter?. RE: High Air Filter Restriction - Hunter013 - 03-18-2026 A few days later the truck came back with a def light on the dash. Ran a forced regen and that seemed to fix everything. |
