| I found a way to remove stuck drums without hitting it or heating - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Things that may help others... (/forumdisplay.php?fid=46) +--- Thread: I found a way to remove stuck drums without hitting it or heating (/showthread.php?tid=10537) |
I found a way to remove stuck drums without hitting it or heating - Disonesto - 03-09-2026 Today I found a simple way to remove stuck drums I extended the arms on my vevor 15T puller with some 3/8 chain Stuck drum popped off after like 10 pumps , no hammering or touching I think this the best method without ever worrying about cracking the drum. I needed to get in there to replace my abs sensor. Here is a YouTube video of it I made https://youtube.com/shorts/a5ddux2J4oI?si=JoQJZ1rb8ipjocXk RE: I found a way to remove stuck drums without hitting it or heating - Rawze - 03-10-2026 Necessity is the mother of all invention...lol Thanks for sharing. RE: I found a way to remove stuck drums without hitting it or heating - JimT - 04-22-2026 man, I could have used this idea over the winter when I too had to replace a drive abs sensor. I like that original puller, any additional details about what it is? RE: I found a way to remove stuck drums without hitting it or heating - walterk - 05-09-2026 Gee, and it's only $78. A true game changer. And, again a need for a third hand is just obvious! LOL! RE: I found a way to remove stuck drums without hitting it or heating - JimT - 05-11-2026 I recently saw the same type of tool for sale at Harbor Freight. Priced about the same. Don't own either version so no clue as to comparable quality. But from other products I own from both Harbor Freight and Vevor I'd say they are probably about the same. Maybe even from the same factory. |
