| CM871 ISFM Check Valves - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: CM871 ISFM Check Valves (/showthread.php?tid=10559) |
CM871 ISFM Check Valves - Livingston Trucking - 03-31-2026 I have a CM871 seems to be loosing prime over night. Was wanting to know where the check valves are and does anyone have part #s? RE: CM871 ISFM Check Valves - Rawze - 03-31-2026 (03-31-2026 )Livingston Trucking Wrote: I have a CM871 seems to be loosing prime over night. Was wanting to know where the check valves are and does anyone have part #s? maybe this helps... https://youtu.be/MWiSwgcwIoc?si=vMSK7iQjQE4jXyAz RE: CM871 ISFM Check Valves - hhow55 - 04-01-2026 (03-31-2026 )Livingston Trucking Wrote: I have a CM871 seems to be loosing prime over night. Was wanting to know where the check valves are and does anyone have part #s? The info you need can also be found on quickserve.cummins.com |
