| Looking for programming help - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Looking for programming help (/showthread.php?tid=10572) |
Looking for programming help - ZeroNthedark - 04-10-2026 Hello everyone, I'll try to keep this short. Did a motor swap a couple years ago from 870 to an 871 that Haggai's had worked on. The swapper misrepresented his abilities and gave me a half-assed finished project. Got some issues fixed myself, Allison and Jerry fixed some more. I think the major issue is that the program needs some reworking. None of my old parameters were copied over (like rear end ratio, that sure killed it) and even though Jerry got me up and running by getting some tweaking done, it still leaves a lot to be desired. Unfortunately I was never able to get another appointment down there or I would drive back to ATL tomorrow. What I'm hoping to find is someone within a few hours of the western PA area. I would rather take a drive than try to figure out Calterm 5.16. Using Insite is not a big deal, but C-term is just beyond my patience level right now, at least that version. Thanks for your time, any help or suggestions are very welcome! RE: Looking for programming help - Rawze - 04-11-2026 Copy program from ECM and e-mail it to me. It will be far easier for someone to go over the program and see what is missing, etc.. than it would be for paying someone hours of shop time for something they may or may not even be able to figure out. info: https://rawze.com/forums/showthread.php?tid=8425&pid=72945#pid72945 |
