isx 15 boost problems - Printable Version
+--- Thread: isx 15 boost problems (/showthread.php?tid=10589)
isx 15 boost problems - JED - Yesterday
looking for some help i have an isx 15 we deleted roughly 7 years ago. No issues, the customer brought it in thinking he had a turbo issue the problem is the boost surg's up and down, can feel it in the truck. other issue is it will build 20 psi boost by just reving it up in the shop. Could this be the ecm reset ive heard about in the past? Turbo swipe is fine, actuator passes calibration. Back pressure tube is clear, blew out intake pressure sensor.. No active codes to go by, no turbo related inactive codes either. Any help is apreciated
RE: isx 15 boost problems - Rawze - Yesterday
start by copying the program from the ecm and e-mail it to me to have it properly reviewed.
- No one knows what someone did in there, or the toll it may have taken on the engine/turbo for that many miles of run time. - Never assume its good just because it seemed to run ok for a while. That is a big mistake that many people make to assume something is ok just because they have not seen a failure yet.
this statement...
(Yesterday )JED Wrote:  ...Could this be the ecm reset ive heard about in the past?
sounds like a bunch of horse-s$#itthat someone said off the facefooks to me.. cummins ECM's don't do such things on their own.
