| Single Screw Rear End - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Single Screw Rear End (/showthread.php?tid=10590) |
Single Screw Rear End - WIMFClay - Today Good afternoon folks, first time posting here. After reading through some posts about fuel economy, I would like opinions/ experience from others on a related subject. To preface this, I mainly haul grain to the same end user about 155 miles each way. 153 of those miles are highway/interstate. Always bounce back empty. Do not haul anything out during the winter months the trucks stay parked. Who here has a single screw with a lift axle in front to make it tandem when loaded? My dad had always wanted to try one but they are quite rare and as far as I last knew they aren't even offered from paccar. That being said I would not mind converting an existing tandem axle tractor into a single drive axle with a lift axle in the front. I believe everyone uses 46k rear for the extra durability. My questions are: Is it worth the work? What is the max hp/tq for a single axle and is the diff the weak link or lack of traction? Is it noticeable power increase? What kind of fuel savings could someone expect from less friction of only one differential and two less tires on the ground when empty (assuming super singles) How much does it affect the light weight? What lift axle did you go with and rough cost? I am not concerned about traction whatsoever because we do not haul during the winter and 90% of the miles are the same exact trip. I am interested to hear from people that have experience building/driving a setup like this. I do think it would be "cool" to bounce back on 6 tires instead of 8 (lift axle on trailer). Plus being a day cab I would think the ride quality may improve by lengthening the wheel base when empty. |
