| ISX 15 Low Boost - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: ISX 15 Low Boost (/showthread.php?tid=10617) |
ISX 15 Low Boost - Amarchionda - 05-30-2026 Hi everyone I just bought this truck it’s a cm870 CPl8518 And the trouble I’m having is I only get 22lbs of boost and the Egts will easily get up over 1000f just bobtailing. I also hooked my empty 53’ steep deck trailer to it and it’s the same for boost and Egts. The truck seems like a dog. The other thing is the engine brakes seems to not work correctly. When I have it on the high setting it only bumps the boost up to about 2-5lbs. Where do I start on this? Thank you!! RE: ISX 15 Low Boost - Rawze - 05-30-2026 == Start by flashing (or re-flashing) the original factory program that belongs in it back in there. == take it on a test drive, monitor the boost in a hard pull.. then do it again with exhaust disconnected behind turbo. see if it picks up a few psi or not. - it could be a clogged exhaust system/muffler. == Do a CAC leak test on it and make sure it does not leak more than 10 psi in 60 seconds when pressurizing it to 30 psi and shutting off air supply. == check to ensure it does not have an after-market branded (garbage) CAC unit on it that is restrictive. there;s a lot more, like using insite to check engine state, fuel control state, and doing tests on that turbo and its actuator, and about a dozen more possibilities on why an ISX would make lower than normal boost. RE: ISX 15 Low Boost - Amarchionda - 05-31-2026 Thank you!! Will be working on it today, wish me luck!! RE: ISX 15 Low Boost - Amarchionda - Today I hooked it up to insite and did the turbo test and the actuator said it passed but only got to 83%. Should it be at 100%? |
