| Replaced isx cm2350 actuator, low power/engine - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Replaced isx cm2350 actuator, low power/engine (/showthread.php?tid=10660) |
Replaced isx cm2350 actuator, low power/engine - Nerv - 07-09-2026 Just replaced my 2013 cummins isx cm2350 turbo actuator, installed and calibrated, engine brake was completely underpowered, and engine power was reduced. I did the install/calibrate on insite again and it passed after a few attempts, it made the engine brake stronger and some power came back but still not as strong as it was before. Does it need to be recalibrated again? What could be going on? RE: Replaced isx cm2350 actuator, low power/engine - Rawze - 07-09-2026 what is boost getting up to in a hard pull? RE: Replaced isx cm2350 actuator, low power/engine - Nerv - 07-09-2026 Around max 28.. RE: Replaced isx cm2350 actuator, low power/engine - Rawze - 07-10-2026 (07-09-2026 )Nerv Wrote: Around max 28.. That is a bit low. Is this the same truck that had the bad program that was repaired?. If so then maybe it needs to be flashed back to a clean factory program, then run it 10 mins to ensure no remnants of bad programming is still caught up in that ecm left over, then send it to me again.. I will re-make it from a clean program. RE: Replaced isx cm2350 actuator, low power/engine - Nerv - 07-10-2026 Yes it was repaired but awhile ago, this is in the peterbilt, it was flashed clean then done by bengy then again by you.. then i rebuilt the engine, didnt have any issues until this actuator change. RE: Replaced isx cm2350 actuator, low power/engine - Rawze - 07-10-2026 (07-10-2026 )Nerv Wrote: Yes it was repaired but awhile ago, this is in the peterbilt, it was flashed clean then done by bengy then again by you.. then i rebuilt the engine, didnt have any issues until this actuator change. I see that it was a few years ago. There has been several updates since then. I will send you your file again with the latest updates in it. RE: Replaced isx cm2350 actuator, low power/engine - mikkhh - Yesterday Did you use torx/allen key to set the actuator lever position on turbo like it should be ? There is hole in actuator lever on turbo that is used to set the position. Then connected actuator just to plug, run the first step of calibration that sets the correct position on actuator and then mount the actuator on turbo and then do the last step of calibration with actuator mounted on turbo. |
