ISX15 to x15 2012 Pete - Printable Version
+--- Thread: ISX15 to x15 2012 Pete (/showthread.php?tid=10666)
ISX15 to x15 2012 Pete - DirtyKarl95 - 07-13-2026
What all is needed go from an ISX15 to an x15 on a 2012 Pete? ISX15 is a cm2250 and the x15 is a cm 2450. I am looking for a solution to re pin the truck to ecm harness. I see they sell a kustom harness just trying to avoid the 2 month wait on the harness. We start harvesting corn next Monday.
ISX15 left the dealership after an oil change and locked up 5 miles down the road. Someone put 10wt hydraulic in it….
RE: ISX15 to x15 2012 Pete - Rawze - 07-13-2026
First of all, I would suggest rebuilding the engine that came with it. If not then a short block and rebuild.
As far as putting a CM2450 engine in its place... the old engine wiring harness, old ecm, old turbo and old exhaust manifold manifold if necessary ... any other sensor swapped over to new engine that does not directly plug into the older harness, etc. - and then have a custom program made for the old ecm to run the newer model engine. The older ecm should also run the newer injectors without issues, so keep the newer injectors.
RE: ISX15 to x15 2012 Pete - DirtyKarl95 - 08-05-2026
Well I did go against advice and did what customer wanted. X15 is in and I am now having issues with abnormal update rates. Specifically the accelerator pedal. I’ve changed it from a dual analog to a pulse width that corrected the voltage codes I was previously having.i also enabled multiplexing for accelerator pedal. Is there a way to turn the ecms Can communication down to 250 to match the rest of the truck as it is currently at 500 baud .? This is a cm2450A ecm
RE: ISX15 to x15 2012 Pete - Rawze - 08-06-2026
(08-05-2026 )DirtyKarl95 Wrote:  Well I did go against advice and did what customer wanted. X15 is in and I am now having issues with abnormal update rates. Specifically the accelerator pedal. I’ve changed it from a dual analog to a pulse width that corrected the voltage codes I was previously having.i also enabled multiplexing for accelerator pedal. Is there a way to turn the ecms Can communication down to 250 to match the rest of the truck as it is currently at 500 baud .? This is a cm2450A ecm
use the old ecu and wiring harness, etc. as mentioned above .. otherwise you have opened a huge can of worms!!!.
