HD turbo in IL - Printable Version
+--- Thread: HD turbo in IL (/showthread.php?tid=10674)
HD turbo in IL - Ricky - Yesterday
So I was off for like six weeks and when I started back to work the truck started acting up. It was showing actuator code, it went into limp mode once and lost power a few times pulling. The turbo and actuator were both replaced August 2017 so it's done well. I was looking around and I thought I saw on here that Jerry was getting turbos from HD Turbo but I might be mistaken. But anyway, has anyone experienced them and if so how were they? Also are there anyone else that I can check out? They are doing a sale on mine with the actuator for 2649.00 and a 250 core on the actuator.
I have been running some short loads because work is busy and I really need the money since I was out for so long. If I keep the boost low I haven't had an issue in two days but I'm just trying to prepare. I haven't pulled the actuator but I pulled the intake pipe and the charge air pipe and I don't have any oil and the wheel is tight. I think it might have carboned up because I started it every few days. Sensors have all been pulled and looked like new.
Truck is a 2008 Prostar with 871, built by Allison in February 2021 and tuned at the same time and only has just over 350,000 on the build.
RE: HD turbo in IL - marek4792 - Yesterday
Their turbos work good, but for whatever reason some of them do not hold oil. Mind you OEM remans do suffer the same issue..
