X15 constant regeneration - Printable Version
+--- Thread: X15 constant regeneration (/showthread.php?tid=10703)
Pages: 1 2
X15 constant regeneration - Therealarw - 08-10-2026
Hi everyone,
I’ve come across one of my trucks and I’m completely stumped on it… It’s a 2019 Peterbilt with an X15 engine in it.. lately it’s been going through a regen almost every single day. Constantly just high rpm at idle when the truck is stopped even when the parking brake isn’t set it goes off. There’s no check engine lights for it nothing inactive or active either. I had an extra DPF DOC and the SCR catalyst from another truck (everything was the same for part numbers) and it’s still going through this regen stage… Only things I haven’t done on it are an ECM calibration, or ran the rack on it or checked the injectors. From what I understand these engines don’t have a 7th injector and instead the 6 fuel injectors are what atomize the fuel that goes into the exhaust system. Another thing before I forget is that I did the aftertreatment maintenance reset when I did the filters. I feel like I’ve looked through about everything on the truck but maybe I am missing something? Part of me feels like maybe the ECM might be glitched and it’s seeing something either pressure or temperature related that actually might be false causing it to constantly regen? I’m not too sure but it’s been a pain in the a** and the driver who drives this trucks worried that it’s gonna eventually hurt the motor. Thank you guys for checking this out and hopefully we can figure this out!
Thanks!
Adam
RE: X15 constant regeneration - marek4792 - 08-10-2026
Did you do a full EGR tune up? - https://rawze.com/forums/showthread.php?tid=8438&pid=73167#pid73167
Have you done injector leak tests on it?. - https://rawze.com/forums/showthread.php?tid=8728&pid=75483#pid75483
Do you have oil consumption more than 1 gallon every 4,000 miles or equivalent hrs?
Did you check the regen history? The InHg shouldn't be more then 3 consistently.
Did you take the down pipe off and snap test to check for large amount of smoke?
Have a friend with a 565 x15 that had similar symptom with daily regens that upon snap testing with the downpipe off literally smoke out the shop, luckily he was at a stealership that knows what to look for instead of blindly following a diag tree.
He got a full set of injectors under warranty luckily...
I personally had a injector not atomize properly (white smoke) that cracked manifolds and eventually the turbo itself until I caught it doing a snap test with the manifold off...
Also recently had an injector get stuck under full load, it didn't misfire either letting off, EGT would go the moon until i freed it up and ran good until being replaced..
You need to figure this out before you service the cans and not fire the parts cannon like the stealerships usually do!!
RE: X15 constant regeneration - Rawze - 08-11-2026
(08-10-2026 )Therealarw Wrote:  ...Only things I haven’t done on it are an ECM calibration, or ran the rack on it or checked the injectors. ...
Thanks!
Adam
First of all,.. take the cans to an OEM stealers$it and have them baked, de-ashed, and flow tested. - the truck engine regen process is incapable of cleaning the DPF fully, and only converts soot into ash that it cannot get rid of.
Make sure any cleaning process while they arer removed does NOT use any liquids, as they will wash out the precious metals, and make DPF half as effective... leading to nox, regen, and other issues.
Also, Re-flashing the ecu software, even if it is the same version, will force-reset all the data in the ecm and make it establish a new base-line. This is far more effective than simply doing maintenance resets... especially if you replaced the cans with new ones.
and yeah... the issues are at the engine not the cans under the truck.. fix the engine .. a full egr tune-up/cleaning, injector tests/replacements, overhead valves, etc.etc. - like was mentioned in the post above.
RE: X15 constant regeneration - Therealarw - 08-13-2026
(08-10-2026 )marek4792 Wrote:  Did you do a full EGR tune up? - https://rawze.com/forums/showthread.php?tid=8438&pid=73167#pid73167
Hey guys sorry for the late reply.. been super busy here at work.. I have not done an EGR tune-up on it yet, I was thinking about doing that and cleaning out the cooler because it actually hasn't been done at all... I also did think about the injectors maybe one isn't atomizing the way it's supposed to or a couple of them so I was thinking of doing that next.. There's no oil consumption though. Looking at the DPF differential pressure I see average about 2.5 inHG. My next move is to take the pipe off and check to see how everything looks. I will let you guys know what I find out.. I also thought about running the rack and making sure the valves are all adjusted right
RE: X15 constant regeneration - Therealarw - 08-26-2026
Hey guys so I went ahead and took off the EGR cooler EGR valve (saw a little leak in one of the portholes on the valve so I ended up just replacing it. And went through all the injectors and for some reason I’m still getting constant regens. I also did a ECM calibration with Cummins Insite and I also had all the injectors remember replaced too. It’s still giving me a constant continuous regen and I’m pretty much lost and confused with this damned thing. What do you guys recommend I look at on Insite to really see what’s going on? Everything looks good as far as no leak in the exhaust system no leaks on the filter side no injector leaks none of that. Thank you
RE: X15 constant regeneration - Rawze - 08-26-2026
maybe post the regen history, etc?.
RE: X15 constant regeneration - Therealarw - 08-31-2026
(08-26-2026 )Rawze Wrote:  maybe post the regen history, etc?.
Here is a pic of the regen history the last 10… is there anything that sticks out to you?
RE: X15 constant regeneration - Rawze - 08-31-2026
Yup... those numbers are high across the board.
re-read post #3 about having cans pulled, baked, etc.
and take pics of their faces as they come off.
RE: X15 constant regeneration - Therealarw - 09-02-2026
Okay! I will take them off. We don’t really have too many people that do the cleanings around here especially Cummins dealershixts but let me see what I can do and I’ll post some pics. What about the one very end “filter” I don’t know what they call that one but it’s the one that the outlet pipe connects to. Do I need to have that one cleaned also? Thank you Rawze!!
