metafiles - Printable Version
+--- Thread: metafiles (/showthread.php?tid=10731)
metafiles - farmtrucknw - 08-27-2026
Who can I get metafiles from? I have Calterm and would like to copy off my ecm file and try to see if I can tackle some MM edits myself. Looking for a BDR 9.40.16.85.
Thanks.
RE: metafiles - Rawze - 08-28-2026
soft3are trading is not allowed on the forum
as far as learning more about programming side of things, and not tearing the guts out of the engine in the pr0cess, that is what the mumble server is for.
The proper place to discuss engine/ecu programming, tuning, using Calterm,
etc. is over on my mumble server. If someone is serious about getting involved
in detailed discussions on these subjects, then that is the place to be.
This also includes free professional level training/help ...
== How Enigne control modules work and their typical logic structure.
== Overall system circuit and management structure with regard to programing.
== Discussions about engine tuning software, including CT and others.
== CLasses on EGR, boost, Compression ratio, Injection timing, and all
other relevent topics with concern to ecm programming.
== Assisitance writing your own programming so that it does not shorten
engine life.
... and much more.
The mumble software itself is free, and it costs nothing to participate.
== On the PC, the program is called 'Mumble'. On the smart-phone it is often
called 'Mumla', or 'Plumble', or 'Mumble', it depends on the brand of phone.
The server is private and unlisted, so it has to be added manually when you
join for the first time.
== The private server address is ' mumble.rawze.com '.
Here is a link to the mumble software for the PC:
https://www.mumble.info/
Here is some additional info for setting up mumble / getting onto our
private server specifically:
http://rawze.com/forums/showthread.php?tid=53&pid=2163#pid2163
