| Dash brake valve leaking when foot brake is pressed - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Dash brake valve leaking when foot brake is pressed (/showthread.php?tid=10752) |
Dash brake valve leaking when foot brake is pressed - Redland1 - 09-14-2026 I’m having the yellow knob on the dash leak briefly every time I press the foot brake. The rod knob leaks continuously when I pull the Johnny bar. What could be the issue ? RE: Dash brake valve leaking when foot brake is pressed - Rawze - 09-15-2026 maybe this helps... https://rawze.com/forums/showthread.php?tid=10384&pid=85317#pid85317 https://rawze.com/forums/showthread.php?tid=7257&pid=63967#pid63967 https://rawze.com/forums/showthread.php?tid=4434&pid=37701#pid37701 |
