ISX CM871 Turbo Sceech/Squeal - Printable Version
+--- Thread: ISX CM871 Turbo Sceech/Squeal (/showthread.php?tid=10770)
ISX CM871 Turbo Sceech/Squeal - Livingston Trucking - 09-27-2026
I have a CM871 with a bad screeching/squeal that comes and goes, not consistent. Only does it when using Stage 3 Jakes loaded.
No other issues, pulls stong, strong jakes etc.
Where and what should I start looking at?
RE: ISX CM871 Turbo Sceech/Squeal - marek4792 - 09-27-2026
Usually exhaust manifold/turbo gaskets, but could be loose hardware if work was done recently. If the slip joints are in a bind especially when hot could momentarily cause a brief squeal that goes away after awhile.. Or the manifold itself could be warped if original high mileage or a cheap aftermarket.. Just my opinion dealing with my old 870 that had the exact symptom..
RE: ISX CM871 Turbo Sceech/Squeal - Yauchout - 09-27-2026
marek is correct that is the most common cause. it should be noted the nuts that hold the turbo on are one time use if they were re used after recent turbo removal they have likely started backing off
RE: ISX CM871 Turbo Sceech/Squeal - Rawze - Yesterday
(09-27-2026 )Livingston Trucking Wrote:  I have a CM871 with a bad screeching/squeal that comes and goes, not consistent. Only does it when using Stage 3 Jakes loaded.
This kind of noise is never the turbo.. despite it sounding like it...
older forum references for this ...
http://rawze.com/forums/showthread.php?tid=1829&pid=15618#pid15618
and...
http://rawze.com/forums/showthread.php?tid=2610&pid=22387#pid22387
