Truck having issues going into third gear - Printable Version
+--- Thread: Truck having issues going into third gear (/showthread.php?tid=10805)
Truck having issues going into third gear - Redland1 - 11-01-2026
Having issues putting the shifter into third gear lately. It’s a 13 speed Eaton Fuller. The day before it started the shifter was twisting when I would try to shift and I found a spot to pull over to check it out. Pulled up on the shifter and it came off the transmission. Ended up opening up the boot and saw that the bolt had come off and was sitting on top of the transmission so I put it back on with a lock nut.
RE: Truck having issues going into third gear - marek4792 - 11-01-2026
Would've been a good time to change out the isolator bushing if you weren't roadside. Lol
RE: Truck having issues going into third gear - Redland1 - 11-02-2026
(11-02-2026 )Rawze Wrote:  thanks for the info. Glad to see you figured it out.
Sorry I explained it wrong. Once the shifter came off the transmission and I secured it was when I started having issues getting the truck into gear especially third gear.
RE: Truck having issues going into third gear - Rawze - 11-02-2026
maybe XT shifter wearing out?.. or maybe the XY shifter cables to the batteries not getting full amperage for the shifter?.
