N14 Injector Solenoid Failure - Printable Version
+--- Thread: N14 Injector Solenoid Failure (/showthread.php?tid=10818)
N14 Injector Solenoid Failure - mechanixrds - Today
Has anyone else come across this issue on a N14 Celect Plus? What's happening is that it keeps breaking the internal plunger on the solenoids and will cause an over fueling condition. It is always #4 injector. I've attached some pictures so you guys can see what I'm talking about.
[attachment=10584]
[attachment=10585]
I've checked cam, cam followers, push tubes, rocker arms and shaft, ohmed out harness and load tested it, pass-through as well, and ecm. Any suggestions guys?
RE: N14 Injector Solenoid Failure - Rawze - Today
N14 should be in a museum by now... I hope like h#ell your not trying to haul freight with an old N14... you need to get rid of it and buy something 25+ years newer at this point.
DO NOT EXPECT any injectors or other parts to be worth 3 cents on those old antique engines these days.. You could buy 5000 injectors and maybe get 3 that last for more than 1-2 years.. that is how old and out of date and how little there is for reman for them any more... they are a dinosaur of the past.
RE: N14 Injector Solenoid Failure - mechanixrds - Today
It is a customer's truck. I don't drive them. I just fix them.
