Isx cm871 delete 2010 w9 - Printable Version
+--- Thread: Isx cm871 delete 2010 w9 (/showthread.php?tid=10820)
Isx cm871 delete 2010 w9 - 3406E - 11-19-2026
So I went to a shop in Illinois to change my speed sensor in the transmission, I saw that my dpf light had just came on and the mechanic said might as well just delete it same time and I agreed.
After he deleted it, I asked him aren’t you going to use the block off plates?
He said no, because he does his parameters different . WTF.
I’m not a mechanic but don’t you have to block the egr and remove the dpf and block the pipe to the intake?
Now I’m not comfortable with the delete he done, so my plan is to make him put back my original program. After he did what he said was a delete I didn’t see back the dpf light. My original plan was to go to Griffin to get it deleted but I don’t know why I made that dumb decision.
However I have not driven the truck since he said he deleted it because I don’t need my motor to be f*cked up of the stuff he done. I’m still here at his shop camping out till tomorrow.
I may need someone to put back my original program through team viewer tomorrow because I don’t trust this guy to do it. I feel so stupid right now, because I know better.
PLEASE HELP, AND TELL ME WHAT I SHOULD DO FROM HERE
54k on a full rebuild / new turbo & egr cooler
Cpl:3320
Serial:79398203
Factory Spec: 600hp 2050 trq
RE: Isx cm871 delete 2010 w9 - Rawze - 11-19-2026
Sounds to me like the typical chit-show shop experience to me... and so many people wonder why there are so may bad de-mandates out there.
Read this post,.. and get a hold of one of the people listed at the bottom of the article if you do not want to handle it yourself...
https://rawze.com/forums/showthread.php?tid=8425&pid=72945#pid72945
