| Factory qalcomm - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: Factory qalcomm (/showthread.php?tid=1141) |
Factory qalcomm - 74bassman - 11-22-2016 I have a 2010 prostar. Between the bunk and the floor cabinet on the left side there is a box for e logs. I don't use this box, and I believe it is factory installed. Is there any use that I could get out of this? I'm thinking about removing it and all cables for it. I don't have the actual dish on the back of the sleeper, but the cables are there. I also don't have the key board for this, but the cable is there. If I remove this will it cause any problems. RE: Factory qalcomm - T680 - 11-23-2016 U shoudn't have no problem on removing the cables in /out just disconnect them carefully from the fuse box I've removed them many times myself when I left the co where I had to have them with or wo the e logs They just don't want the cables back only the communication hardware at the end.. I still see many trucks with the cable hanging on the back of a cab , some even marking the paint.... RE: Factory qalcomm - 74bassman - 11-23-2016 On the driver side under the door sil, I see where they have the plugs that supply the power. I should be able to unplug these, and not cause any issues? RE: Factory qalcomm - T680 - 11-24-2016 Door sil ???? I'm Not bright enough to get it ...sorry RE: Factory qalcomm - 74bassman - 11-25-2016 The panel right as you open the door with the logo on it. |
