EGR BOLTS FROZEN - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: EGR BOLTS FROZEN (/showthread.php?tid=1145) |
EGR BOLTS FROZEN - 1096 - 11-22-2016 Doing EGR tune on an 09 cm871 and can't break the 2 10m bolts loose holding the exhaust tube on top of EGR. Any suggestions would be welcome. RE: EGR BOLTS FROZEN - Rawze - 11-22-2016 50/50 mix of dextron 3 and acetone. Likely you will be obligated to remove the EGR valve if you break one of them off (happens very often), drill out the hole, and use a longer screw, lock washer, and nut to replace it. |
