| Coolant System cummins isx - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Coolant System cummins isx (/showthread.php?tid=1180) |
Coolant System cummins isx - Sanat123 - 12-01-2016 Did any one had this problem ? all hose that connects to the radiator is pumping, and loosing anti freeze coolant from the top of the reservoir antifreeze tank. Loosing about 6-7 gallons of antifreeze coolant each week. I've replaced the air compressor, after two weeks the problem was still there. After that I've replaced the thermostat and new reservoir antifreeze tank. After all the the replacements the problem did not go away! if anyone had the same issue and know what may caused the problem i would really appreciate your advice. RE: Coolant System cummins isx - Hedley - 12-01-2016 thats a lot of coolant, worst case scenario...head gasket. ![]() get a compression in coolant test kit. ![]() |
