| EGR delete - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: EGR delete (/showthread.php?tid=119) |
EGR delete - scowman - 03-01-2016 any comments or suggestions? How about any suggestions on a place to have it done. Thanks RE: EGR delete - preacherboy24 - 03-01-2016 (03-01-2016 )scowman Wrote: any comments or suggestions? I PM'ed you. We dont condone this sort of thing unless its for off road use. Discussing this is better on the member only page or PM's. RE: EGR delete - Running rough - 03-01-2016 This is asuming your from a country which allows such things, I would pm Rawze Unilevers or Gearhead RE: EGR delete - scowman - 03-02-2016 got it would actually be for a truck converting to a water truck so yes technically off road. thanks |
