FAULT CODE 2372 ISX 871 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: FAULT CODE 2372 ISX 871 (/showthread.php?tid=1219) |
FAULT CODE 2372 ISX 871 - rgreen - 12-12-2016 09 prostar throwing a fault 2372 and it is also causing low acceleration. Any help will be nice also change one fuel filter and i am going to change the other today F203. Does anyone one know the location of the low suction fuel filter FF203. RE: FAULT CODE 2372 ISX 871 - Rawze - 12-12-2016 (12-12-2016 )rgreen Wrote: 09 prostar throwing a fault 2372 and it is also causing low acceleration. Any help will be nice also change one fuel filter and i am going to change the other today F203. Does anyone one know the location of the low suction fuel filter FF203. Code 2372 -- "Fuel Differential Pressure Above Normal" Happens when you loose main fuel pressure in the fuel system while trying to drive. * Bad fuel, clogged fuel filter, Clogged pre-filter, Sucking Air, etc. * Also can be bad gear pump. <- this is a very common cause of this fault too. Failure of the gear pump is also associated with failure of the electric lift pump. If your electric lift pump is not in good shape, it will destroy the gear pump as it fails, so If your gear pump is bad, replace the electric lift pump along with it as a preventative measure if it is old too. RE: FAULT CODE 2372 ISX 871 - rgreen - 12-12-2016 Rawze do you know where the suction side mirco fiber filter is located???? RE: FAULT CODE 2372 ISX 871 - rgreen - 12-12-2016 Never mind my wife got the wrong filter she got a glass looking filter, I feel so dumb |
