Schaeffer gear lube - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Schaeffer gear lube (/showthread.php?tid=1245) |
Schaeffer gear lube - rgreen - 12-16-2016 Has anyone use Schaeffer gear lube for there differential, or can someone recommend a good gear lube, the truck as pretty close to 930,000 miles on it, I dont know what the previous owner as done, after the new year, I will be doing inframe on the engine. Also I would like to change the fluid in the tranny, Thank you in advance for your input. Merry Christmas and Happy Holidays!!!!!! RE: Schaeffer gear lube - Rawze - 12-17-2016 Tried lucas in my steer axle hubs once,.. It foamed up a lot.. even after a couple flushes just to be sure .. and it looked like crap. - I Had to go back to Mobil. That sucks too, because I had gotten 4 gallons of it. - I ended up lighting camp fires with it. I have more than a million on my drive line, tranny, rears, etc. I have always used Mobil Synthetic on the gear boxes and tranny. I am thinking I am ready for a new clutch yet? it has never been changed either .. -- but then again, the indicator says it is only worn by 45%. I don't go 70+ mph, I go 55-60 mph the whole trucks life and keep boost below 20. - A decent oil and taking care how you drive makes the most difference I think. |
