| OEM Software question - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: OEM Software question (/showthread.php?tid=1248) |
OEM Software question - RSCTRANS - 12-17-2016 I have five trucks. Four of them have Cummins motors in them. I already have Cummins insight. I was wondering if I can purchase separate programs to check manufactures codes? I have a freightliner, Kenworth, international, and two Volvo's. is separate OEM programs available for me to check the individual manufacture codes? If so where can I go to purchase them? RE: OEM Software question - rgreen - 12-17-2016 (12-17-2016 )RSCTRANS Wrote: I have five trucks. Four of them have Cummins motors in them. I already have Cummins insight. I was wondering if I can purchase separate programs to check manufactures codes? I have a freightliner, Kenworth, international, and two Volvo's. is separate OEM programs available for me to check the individual manufacture codes? If so where can I go to purchase them? If you want to just pm me I might can help you out RE: OEM Software question - snailexpress - 12-18-2016 (12-17-2016 )RSCTRANS Wrote: I have five trucks. Four of them have Cummins motors in them. I already have Cummins insight. I was wondering if I can purchase separate programs to check manufactures codes? I have a freightliner, Kenworth, international, and two Volvo's. is separate OEM programs available for me to check the individual manufacture codes? If so where can I go to purchase them?Insite Fault Viewer will work with any truck and show what is wrong in basic. https://insite.cummins.com/downloads/pcfaultviewer.html RE: OEM Software question - rgreen - 12-18-2016 (12-18-2016 )snailexpress Wrote:(12-17-2016 )RSCTRANS Wrote: I have five trucks. Four of them have Cummins motors in them. I already have Cummins insight. I was wondering if I can purchase separate programs to check manufactures codes? I have a freightliner, Kenworth, international, and two Volvo's. is separate OEM programs available for me to check the individual manufacture codes? If so where can I go to purchase them?Insite Fault Viewer will work with any truck and show what is wrong in basic. I pm you hopefully this will help you RE: OEM Software question - snailexpress - 12-18-2016 Video is promising. Thank you will check it Monday if i can dig out nugget. |
