Fuel used at idle? - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Fuel used at idle? (/showthread.php?tid=1325) |
Fuel used at idle? - Johnboy - 01-06-2017 Just out of curiosity has anyone sat down and figured how much fuel is used during idle time? I have done it twice on two different trucks and the number came out to be close to the same on both. I'm not sure exactly how much fuel is used I know I don't belive for a second the b.s. 1 gal an hour. RE: Fuel used at idle? - Signature620 - 01-06-2017 If you have access to calterm, monitor the live fueling rate and do the maths there. You'll get the exact amount that way. RE: Fuel used at idle? - uncleal13 - 01-06-2017 My trucks: 1998 Detroit = 2 litres per hour 2006 MBE4000 = 4.2 litres per hour 2013 DD15 = 4 litres per hour 2016 DD16 = 3.3 litres per hour RE: Fuel used at idle? - Billdozer2 - 01-06-2017 I have a 2013 ISX 2250 in my Volvo. If the turbo is spooled up at idle, I'm guessing to heat the DPF, it uses almost 2 gallons an hour. If the turbo is at rest, the engine uses 0.6 gallons an hour at idle. RE: Fuel used at idle? - preacherboy24 - 01-06-2017 Mine varies but its around half gallon per hour. If I bump up the idle it gets around the one gallon mark. |
