| power steering - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Other truck related Help... (/forumdisplay.php?fid=71) +--- Thread: power steering (/showthread.php?tid=133) |
power steering - BSTRUCK - 03-03-2016 sometimes stops working when backing in a small seal leak at top ? RE: power steering - preacherboy24 - 03-03-2016 There should be a filter on the reservoir and it could be causing restriction.....but I doubt it. If you have a leak maybe the high pressure side is leaking into the low pressure side. Does it completely loose power or does it just get weak? If it completely loses power and comes back I would prolly say there is a valve in the system that is sticking.....and prolly not serviceable. RE: power steering - BSTRUCK - 03-03-2016 it completely gone seem after finsh backing for 10 min into parking spot pull bakes and sit a few min. its fine it will happen 1 to 2 months apart still a work out when it does RE: power steering - preacherboy24 - 03-03-2016 (03-03-2016 )BSTRUCK Wrote: it completely gone seem after finsh backing for 10 min into parking spot pull bakes and sit a few min. its fine Sounds like its sucking air. When it does it again check the fluid right away and see if its a frothing strawberry milkshake. RE: power steering - Rawze - 03-04-2016 when is the last time you changed the oil out and filter? Power steering is one of the most neglected systems on trucks. RE: power steering - Old Driver - 07-20-2016 If your power steering is turning black it might be leaking oil into it and time to replace power steering pump. |
