cleaning egr - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: cleaning egr (/showthread.php?tid=1382) |
cleaning egr - flonly - 01-23-2017 Hi to all.I have a 08 isx 871 it has 1.2 million miles on it.I have done egr tune up a few times and just did it a week ago i changed the egr 1 year ago and keept the old one.my question is can i take it apart and just keep cleang them so when i do the egr tune up every year i can put a clean one in. RE: cleaning egr - gatow900 - 01-23-2017 As long as the valve seals I don't see a problem. When my egr cooler took a dump I had charcoal in it. So I took it apart cleaned it and checked if it seal and it did. So I put it back saved $950 bucks |
