| How i do PC injector\cylinder test ISX (hydrolic ones ) - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: How i do PC injector\cylinder test ISX (hydrolic ones ) (/showthread.php?tid=1392) |
How i do PC injector\cylinder test ISX (hydrolic ones ) - ceff_by - 01-25-2017 Here is my experience. Its known issue that finding bad (well, not well doing injector) its a bit tricky with ISX. Cylinder perfomance test doesnt do well in all cases, pass pas pass but there is obviously something wrong. So what i`m doing first -- cutout test 1. one by one -- nothing. 2. 5 off, one left, 1-2 seconds its abt to die then reenable all. Test all all 6 in that way. Sometimes it can work pretty long time on 1 cylinder (5 cutted off) -- means injector(s) is leaking. 3. It sometimes help to locate leaking one if customer doesnt have\doesnt want to replace all of them -- do check valve leak test. Then immediatly after start run cylinder perfomance test. Sometimes it will show you for a short time "fail" on some cylinder(s). 4. to catch bad bank (fuel\timing solenoid) sometimes youll have to gently play with accelerator for a bit (up to 900 and drop back). In some cases it will show for a short period #pass pass pass fail fail fail# (On 870 -- there is "front bank" "rear bank" pass\fail) means rear bank is bad. Its not 100% metodic but give you much more then single cutout, or if cyl perfomance shows nothing. I think there is another way -- pull calibration and see injector responses. Didnt try that yet, want to see opinions. RE: How i do PC injector\cylinder test ISX (hydrolic ones ) - Rawze - 01-26-2017 I have really never had problems helping someone find leaky or problematic injectors. I simply perform a leak test on them BEFORE doing any cut-out tests, etc. and then do cut-out test only after you have verified you have no leaky injectors. then followed by... <iframe id="lbry-iframe" width="560" height="315" src="https://lbry.tv/$/embed/insite-cylinder-cutout-test-by-rawze/745408fe6eb4b6196b74d576cf52cd1d420c03a3" allowfullscreen></iframe> RE: How i do PC injector\cylinder test ISX (hydrolic ones ) - un_yun - 01-30-2017 I have a skip under load and boost. It passed the leaked down. I do not have insite yet. So I took a temp gun to the exhaust. All are 300 +/- 10 degrees. Except # 1 it runs around 240 degrees. Is sixty degrees enough to cause a heavy skip when loaded under a pull, but barely noticeable under light load. The skip seems to come on at high boost. |
