| Bendix Air Dryer "Ticking" 2008 ProStar - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: Bendix Air Dryer "Ticking" 2008 ProStar (/showthread.php?tid=1453) |
Bendix Air Dryer "Ticking" 2008 ProStar - Waterloo - 02-09-2017 Hey guys, a few weeks ago my air dryer started ticking. I replaced the cartridge when I serviced the truck at my local TA the other day. The old cartridge was pretty messy. I change them out annually as I normally don't drive much more than 70,000 miles a year and rarely idle. Just surprised how gummed up looking she was. But anyhow, she is still ticking, and this being kind of an odd ball air dryer unit, what do you think it is? I cannot get under there to inspect as the truck sits to low, air dryer is stuffed up under the cab on the inside of the frame rail under the cab. Stupid location... I'm thinking purge valve? Any thoughts? Still operating normally, just ticking... RE: Bendix Air Dryer "Ticking" 2008 ProStar - Brock - 02-09-2017 Mine was doing that last winter. It was semi froze up. Ran airline alcohol through right off the compressor and she was good. RE: Bendix Air Dryer "Ticking" 2008 ProStar - Waterloo - 02-09-2017 Cool, I'll run some through. Thanks. RE: Bendix Air Dryer "Ticking" 2008 ProStar - SquareOne - 01-08-2020 Waterloo, which style air dryer do you have? I don't have an issue, but wanted to get some feedback on an OEM Bendix replacement cartridge vs some of the cheaper aftermarket versions. My truck has a Bendix AD-IP style (the cartridge is the spin on version--part number 065624 according to Bendix). |
