Engine fan staying on - Printable Version
+--- Thread: Engine fan staying on (/showthread.php?tid=1482)
Pages: 1 2
RE: Engine fan staying on - 386lover - 02-18-2017
My IH 9200 had the fan clutch go out and then the default is to lock the cluctch to make sure the motor doesn't overheat.
RE: Engine fan staying on - Nilao - 02-19-2017
I know on my prostar if the air pressure is under 90 psi the ecm will engage the fan. Also I would check the IMAP sensor. If it's reading a high intake temp it will trigger the fan to come on.
RE: Engine fan staying on - Signature620 - 02-19-2017
Even if the A/C isn't working, the pressure switch can fail. If you have INSITE you can monitor the switch and see.
RE: Engine fan staying on - Brock - 02-19-2017
Shut the truck off for 20 minutes and now it's fine. I'm replacing every wiring harness on this truck anyways because internationals are junk when it comes to wiring. Every ihc I've ever owned had major external wiring issues.
RE: Engine fan staying on - Rawze - 02-19-2017
(02-18-2017 )Brock Wrote:  My ac hasn't worked in years. Line rotted out, zero pressure in there.
thanks. I corrected my post above.
Still though, if your A/C pressure switch has a bad connection or has gone bad, it will make the engine fan stay on.
