Code 1117 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Code 1117 (/showthread.php?tid=1502) |
Code 1117 - Shanman - 02-23-2017 Truck died going down the road. Got it to a shop. Getting code 1117 power loss with key on. I have continuity tested all wire and they all check out. Have visually traced all wires all look good. Replaced ecm and truck will run for a few seconds and die. I don't know what else to do please help. RE: Code 1117 - snailexpress - 02-23-2017 (02-23-2017 )Shanman Wrote: Truck died going down the road. Got it to a shop. Getting code 1117 power loss with key on. I have continuity tested all wire and they all check out. Have visually traced all wires all look good. Replaced ecm and truck will run for a few seconds and die. I don't know what else to do please help.ECM power inline fuse. RE: Code 1117 - Shanman - 02-23-2017 The fuses in the battery box?? Changed them still same thing. RE: Code 1117 - snailexpress - 02-23-2017 What is truck make and year? RE: Code 1117 - Shanman - 02-23-2017 2009 pete 386. All fuses replace. They think the ecm is bad again RE: Code 1117 - Rawze - 02-23-2017 (02-23-2017 )Shanman Wrote: 2009 pete 386. All fuses replace. They think the ecm is bad again I bet I could most likely find it in 5 minutes and i don't even own one ... How come the people who work on them for a living can't do this? -- it is very common issue with them ... most likely culprit(s) -- http://rawze.com/forums/showthread.php?tid=469&pid=3505#pid3505\ and this (ecm)... http://rawze.com/forums/showthread.php?tid=1447&pid=12320#pid12320 And then there is this (somewhat related) .. http://rawze.com/forums/showthread.php?tid=1481&pid=12551#pid12551 also make sure it is not fuel related. http://rawze.com/forums/showthread.php?tid=1372&pid=11426#pid11426 RE: Code 1117 - Shanman - 02-23-2017 Rawze, I showed them the first link yesterday. Went through all those spots everything was good. So they bypassed everything and ran a power wire to the ecm. Same thing. This has a brand new ecm in it. We took an ecm off another truck they had in the yard and truck ran fine. So I guess I got a bad brand new ecm?? They are overnighting me a new ecm. What are the chances I received an ecm that was bad. The second link is what my first ecm was doing truck would run but if you tapped on the ecm it would kill the truck that's why we replaced the ecm in the first place. |
