| Power Steering Fluid Filter? 2008 ProStar - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: International Trucks Related Help (/forumdisplay.php?fid=69) +--- Thread: Power Steering Fluid Filter? 2008 ProStar (/showthread.php?tid=153) |
Power Steering Fluid Filter? 2008 ProStar - Waterloo - 03-07-2016 All right, still learning... 2008 Prostar, ISX, where is the power steering filter located? Is it inside the reservoir? Thanks! RE: Power Steering Fluid Filter? 2008 ProStar - PuroCumminsPower - 03-07-2016 Yes sir, its inside the reservoir. RE: Power Steering Fluid Filter? 2008 ProStar - Rawze - 03-07-2016 (03-07-2016 )Waterloo Wrote: All right, still learning... 2008 Prostar, ISX, where is the power steering filter located? Is it inside the reservoir? Yup, it is inside the reservoir removing/unscrewing the larger outer black piece at the top will reveal it. RE: Power Steering Fluid Filter? 2008 ProStar - Waterloo - 03-07-2016 Thank you both! ;-) |
