SPN 3226 FMI 10 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: SPN 3226 FMI 10 (/showthread.php?tid=1536) |
SPN 3226 FMI 10 - Billdozer2 - 03-03-2017 Hey guys, so the "Time to open your wallet" light, aka Check Engine Light, came on today. Checked with Insite, SPN 3226 FMI 10 Aftertreatment Outlet NOx Sensor Circuit - Abnormal Rate of Change. After looking at the diag tree in quickserve, it seems that the outlet NOx sensor malfunctioned and needs to be replaced. Anyone else have any experience with this fault before I go digging into it later today? Truck has 442k miles and I have never replaced the NOx sensors (which I guess is pretty good). The fault also shows "Inactive" now, but I know if I just clear it, it will come back. They always do. I thought about swapping the inlet and outlet NOx sensors to see if the fault moves with the sensor. Or I could finally "fix" my truck, the right way, and be done with it. Thanks! RE: SPN 3226 FMI 10 - snailexpress - 03-03-2017 (03-03-2017 )Billdozer2 Wrote: Hey guys, so the "Time to open your wallet" light, aka Check Engine Light, came on today. Checked with Insite, SPN 3226 FMI 10 Aftertreatment Outlet NOx Sensor Circuit - Abnormal Rate of Change. After looking at the diag tree in quickserve, it seems that the outlet NOx sensor malfunctioned and needs to be replaced. Anyone else have any experience with this fault before I go digging into it later today? Truck has 442k miles and I have never replaced the NOx sensors (which I guess is pretty good). The fault also shows "Inactive" now, but I know if I just clear it, it will come back. They always do. I thought about swapping the inlet and outlet NOx sensors to see if the fault moves with the sensor. Or I could finally "fix" my truck, the right way, and be done with it. Thanks!You can not swap sensors they are different. RE: SPN 3226 FMI 10 - Billdozer2 - 03-03-2017 (03-03-2017 )snailexpress Wrote: You can not swap sensors they are different. Thank you. I figured they were the same, but wasn't sure if they could be swapped. Now I know. RE: SPN 3226 FMI 10 - Broke Again - 11-15-2020 I have the same code on 2015 VNL w ISX15. Would someone be able to tell me where the sensor is located? Thanks! RE: SPN 3226 FMI 10 - Broke Again - 11-15-2020 I found it. Thanks!! RE: SPN 3226 FMI 10 - Rawze - 11-15-2020 if you have not registered your engine on cummins.quickserv yet then you should do so. All manuals and procedures and parts are there. the account is free. |
