Any shops around St Louis - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Any shops around St Louis (/showthread.php?tid=1543) |
Any shops around St Louis - Dd614 - 03-05-2017 Anyone no any good shops around St Louis? I have 2008 KW t660 with 871 truck runs for 10 minutes and shots down. I have two codes. 0254 and 0255. I replaced the fuel solenoid it didn't help. Any help will be appreciated thanks. RE: Any shops around St Louis - scottydogtruck - 03-05-2017 (03-05-2017 )Dd614 Wrote: Anyone no any good shops around St Louis? I have 2008 KW t660 with 871 truck runs for 10 minutes and shots down. I have two codes. 0254 and 0255. I replaced the fuel solenoid it didn't help. Any help will be appreciated thanks. I-255 on the IL side, exit 15. Peterbilt shop....open 24 hours except for the weekends....0730-1730 until Monday....my Pete is in the shop there now for an S-Cam problem on my steers. RE: Any shops around St Louis - hhow55 - 03-05-2017 (03-05-2017 )Dd614 Wrote: Anyone no any good shops around St Louis? I have 2008 KW t660 with 871 truck runs for 10 minutes and shots down. I have two codes. 0254 and 0255. I replaced the fuel solenoid it didn't help. Any help will be appreciated thanks. You may have a harness problem, for the wire that goes to your fuel shutoff solenoid. RE: Any shops around St Louis - Squish099 - 03-05-2017 After my recent experience.. I wouldn't take my truck to ANY stealership.. I would be looking for small independent shops that have good following.. They are around you just have to look for them.. Personally anything major is going to be done @ only 1 of 2 maybe 3 shops in the country.. Everything else I'll do if I can.. RE: Any shops around St Louis - Squish099 - 03-05-2017 (03-05-2017 )Dd614 Wrote: Anyone no any good shops around St Louis? I have 2008 KW t660 with 871 truck runs for 10 minutes and shots down. I have two codes. 0254 and 0255. I replaced the fuel solenoid it didn't help. Any help will be appreciated thanks. What does quickserve say the codes are? If you don't have a quickserve account it's free from cummins, if you register your esn to your account.. RE: Any shops around St Louis - Dd614 - 03-06-2017 (03-05-2017 )Squish099 Wrote:(03-05-2017 )Dd614 Wrote: Anyone no any good shops around St Louis? I have 2008 KW t660 with 871 truck runs for 10 minutes and shots down. I have two codes. 0254 and 0255. I replaced the fuel solenoid it didn't help. Any help will be appreciated thanks. Engine Fuel Shutoff Valve Driver Circuit - Voltage Above Normal or Shorted to High Source. Open circuit or short to voltage source detected at fuel shutoff valve circuit. I bypassed the fuel shut off valve made it to Peterbuilt will see what they say tomorrow RE: Any shops around St Louis - Rawze - 03-06-2017 (03-06-2017 )Dd614 Wrote:(03-05-2017 )Squish099 Wrote:(03-05-2017 )Dd614 Wrote: Anyone no any good shops around St Louis? I have 2008 KW t660 with 871 truck runs for 10 minutes and shots down. I have two codes. 0254 and 0255. I replaced the fuel solenoid it didn't help. Any help will be appreciated thanks. Mine did that once. I took the guts out of it and it has been like that ever since. |
