| Coolant temp jumping up and down - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Coolant temp jumping up and down (/showthread.php?tid=1584) |
Coolant temp jumping up and down - littlej - 03-15-2017 I have a 2012 KW T660 with a cummins ISX and my coolant temperature is jumping up to 220 or higher & then comes back down quickly. I changed the temp sensor & the thermostat and when I start it up the temperature went to over 200 almost immediately causing the stop engine light to come on and after idling it for a few minutes it's goes down for a few minutes then back up again. Anybody else experience this? Any help would be appreciated. RE: Coolant temp jumping up and down - Rawze - 03-15-2017 The brass ring/turkon seal in the bottom of the thermostat housing will cause this too. Always change it when changing thermostat. |
