| CM871 Vibration Help - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: CM871 Vibration Help (/showthread.php?tid=160) |
CM871 Vibration Help - kummer17 - 03-08-2016 I have a buddy that had a said name delete done to his truck and has had a problem with what he thinks is the tuning....He says when he gets to a certain RPM his truck has a vibration under the floor near were the pedals are but says the vibration feels like it's being caused by improper timing. Any suggestions would help thanks! RE: CM871 Vibration Help - Cuya - 03-08-2016 I PM you some names |
