| School me on coolant - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: School me on coolant (/showthread.php?tid=1605) |
School me on coolant - Brock - 03-19-2017 I've seen it talked about here and there buy a couple people. Checking your ph level in the coolant, seen rawze talk about adding a additive to replenish. So let's learn what some of you do.... What do you use to test? What levels are normal? That's the ph levels, do you test for silica breakdown? A radiator shop once told me silica was the most important thing...... Also does anyone have knowledge of cummins selection of coolants? Boy they have alot of types. Thanks RE: School me on coolant - Rawze - 03-19-2017 Seen quite a few engines torn down and I see the least amount of coolant problems from ELC red. That is simply what I use now too. RE: School me on coolant - Brock - 03-20-2017 I use the red too, I just seen all sorts of organic and what not colors on Thier website. RE: School me on coolant - jorden486 - 04-01-2017 I use green in my trucks but we are very diligent about checking it. We use test stripes from peterbilt and an additive called DCA to control Ph. |
