| Turbo sliencer ring - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Turbo sliencer ring (/showthread.php?tid=1651) |
Turbo sliencer ring - marek4792 - 04-03-2017 So browsing the interwebs I noticed in the pick up truck world removing the silencing ring seems to be a popular thing to do purely for sound. I have read some speculations about supposed mpg gains and/or losses. Now my question, has anybody experimented with this idea that can confirm or discredit the mpg change theory? RE: Turbo sliencer ring - Rawze - 04-03-2017 (04-03-2017 )marek4792 Wrote: So browsing the interwebs I noticed in the pick up truck world removing the silencing ring seems to be a popular thing to do purely for sound. I have read some speculations about supposed mpg gains and/or losses. Now my question, has anybody experimented with this idea that can confirm or discredit the mpg change theory? At someone else's request, I actually did this and tested this with someone about 2 years ago on ISX with holset turbo. Fuel mileage actually dropped off a tiny bit and it made no significant increase in sound. -- It is a crock of total baloney red-neck pick-up truck butcher bulls$it if you ask me!. RE: Turbo sliencer ring - marek4792 - 04-03-2017 (04-03-2017 )Rawze Wrote: I actually did this and tested this with someone about 2 years ago on ISX with holset turbo. Fuel mileage actually dropped off a tiny bit and it made no significant increase in sound. -- It is a crock of total baloney!. That's what I thought and thinking about it seems like a good way to void warranty if the turbo should fail. RE: Turbo sliencer ring - race7820000 - 04-04-2017 I had a 04 dodge with a cummins that had the ring removed. It sounds like a jet engine getting ready to take off it was so loud when you accelerated. It was annoying, I can see were some kid would think it's cool though lol RE: Turbo sliencer ring - Rawze - 04-04-2017 (04-04-2017 )race7820000 Wrote: I had a 04 dodge with a cummins that had the ring removed. It sounds like a jet engine getting ready to take off it was so loud when you accelerated. It was annoying, I can see were some kid would think it's cool though lol I think the design of the intake on most big trucks quietens this down. I could not really tell a significant sound difference, nor could the truck owner on the pete that we tested after it was all put back together and the hood closed. RE: Turbo sliencer ring - Signature620 - 04-04-2017 Which part is the silencing ring? The shroud plate? RE: Turbo sliencer ring - marek4792 - 04-04-2017 It's in the inlet of the the turbo housing surrounding the turbine held in by a snap ring |
