| Having trouble reading ecm on 2012 Cummins - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Having trouble reading ecm on 2012 Cummins (/showthread.php?tid=166) |
Having trouble reading ecm on 2012 Cummins - Yc123 - 03-09-2016 I have the Cummins insite I been using for 2011 prostar with Cummins. Been working fine with 2011 year. But I been looking to buy 2012 cascadia with Cummins that has def. I have hooked up the cable and insite won't read the ecm keeps saying ecm not connected. Cables plug in fine. Not sure what's going on. RE: Having trouble reading ecm on 2012 Cummins - Rawze - 03-09-2016 (03-09-2016 )Yc123 Wrote: I have the Cummins insite I been using for 2011 prostar with Cummins. make sure your selecting the J1939 protocol. Insite 7.6 and newer should work fine. RE: Having trouble reading ecm on 2012 Cummins - Yc123 - 03-09-2016 Ok thanks I will try that |
