2250 fuel system parameters - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: 2250 fuel system parameters (/showthread.php?tid=1684) |
2250 fuel system parameters - snailexpress - 04-16-2017 If someone will be so kind to post here some insite parameters related to the fuel system 2250. At idle - fuel pressure commanded fuel pressure measured fuel actuator position commanded fuel actuator position measured fuel actuator current commanded fuel actuator current measured. Assume engine is warmed and working good. Thank you. RE: 2250 fuel system parameters - Billdozer2 - 04-20-2017 (04-16-2017 )snailexpress Wrote: If someone will be so kind to post here some insite parameters related to the fuel system 2250. Are you just looking for what another truck's number are? If that's the case, I'll hook up my insite tomorrow (Friday) on my truck and post the numbers here. RE: 2250 fuel system parameters - snailexpress - 04-21-2017 (04-20-2017 )Billdozer2 Wrote:(04-16-2017 )snailexpress Wrote: If someone will be so kind to post here some insite parameters related to the fuel system 2250. Yes, just to check actuator working properly. Thanks. RE: 2250 fuel system parameters - Billdozer2 - 04-21-2017 ![]() Only parameter I could not find in Insite was Fuel Pump Actuator Position Commanded. I also added coolant temp so you could see the engine was warm. RPM was 600. Truck is a 2013 Volvo 400hp "smart" torque 2250 with 455k miles, if that matters. Hope that helps. Let me know if you need anything else. RE: 2250 fuel system parameters - snailexpress - 04-21-2017 Thank you. I have almost same difference in current commanded and measured I was worrying about. [attachment=2732] |
