871 isx 450 max boost - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: 871 isx 450 max boost (/showthread.php?tid=1693) |
871 isx 450 max boost - Mt farmer - 04-20-2017 Can anyone tell me what the max boost should be on a 09 isx 450? What should it go up to on a hard pull? RE: 871 isx 450 max boost - Squish099 - 04-20-2017 871 is 40-41 psi I believe RE: 871 isx 450 max boost - Billdozer2 - 04-20-2017 Rawze wrote in a post in December last year.... (12-24-2016 )Rawze Wrote: * Cap for a CM870/871, that is about 38-39 PSI max pressure. RE: 871 isx 450 max boost - Rawze - 04-21-2017 (04-20-2017 )Squish099 Wrote: 871 is 40-41 psi I believe 40-41 is on the high side for a 871. 36-38 is much better, and they typically go to 38 max with factory programming unless there is something wrong. |
