Def problem keep getting Knox effecent code - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Freightliner related help (/forumdisplay.php?fid=75) +--- Thread: Def problem keep getting Knox effecent code (/showthread.php?tid=1758) |
Def problem keep getting Knox effecent code - Crownvicryder - 05-15-2017 Hey guys I have an 2013 cascadia with DD15 and I keep getting Knox effecent code now I've been chasing this problem for last year and paid out a lot of money to try and fix almost everything under the Def and dpf I've changed with the exception of the big 3 filters but dealer says it has its own code so wouldn't be that. I've replaced def filter , pump ,tank, def pressure sensor, def doser, Knox censor , cleaned the lines thinking they were contaminated and nothing fixed the issue. Now at best it will be good for a week or 2 after dealership says it's fixed then it will derate usually when I'm pulling an 38000 lbs load or more up and down hills . It really dose it when eng has too work and it's hot outside. At this point I'm thinking diesel tuning is only fix I can't keep paying huge repair bills every few weeks . I need help guys please. RE: Def problem keep getting Knox effecent code - Rawze - 05-15-2017 Gearhead and Unilevers both do Detroit stuff. Mr. Hag, just south of atlanta does too, using one of those 2 guys via remotely I think too. PM them your number and be patient, as they can get busy at times. RE: Def problem keep getting Knox effecent code - gearhead - 05-16-2017 This code can be that the one box is bad and is very pricey RE: Def problem keep getting Knox effecent code - Dd15guy - 06-18-2017 I had that same problem Detroit said to replace the one box it was under warranty the entire job was 13k |
