|  Cumnins insite 7.6.2 - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Cumnins insite 7.6.2 (/showthread.php?tid=1783)  |
Cumnins insite 7.6.2 - DonP - 05-24-2017 I have cummins insite v7.6.2. I have not needed to use my software in a while it is on a Windows 7 laptop. Recently I went to use my software and first opened up update manager to get the recent updates and after it updated I got a pop-up Windows saying that my version has expired. Any workaround solutions for that I tried uninstalling it and reinstalling it also tried backdati but to no avail. any help would be appreciated. PM me if you can help, Thank you RE: Cumnins insite 7.6.2 - fargonaz - 05-25-2017 Re-install the OS, unless you would like to spend endless hours messing around with the registry. RE: Cumnins insite 7.6.2 - DonP - 05-26-2017 Thanks for getting up with me. I did find a quick solution {**Content removed by protection bot**- filesharing.} so now my software is working fine  |
