Air coming out of trans beather - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Other truck related Help... (/forumdisplay.php?fid=71) +--- Thread: Air coming out of trans beather (/showthread.php?tid=1784) |
Air coming out of trans beather - marek4792 - 05-24-2017 So I got a RTLO 16913A which leaks air out the breather when black switch is flipped to the hi range, I had just changed the range cylinder o-rings with no luck. No change in sound when red switch is flipped low or hi, and does not leak air when black switch is in low range. RE: Air coming out of trans beather - Mr Hagg - 05-25-2017 TBH I bet you didnt change the oring in the HI/LOW housing. Whe you remove the piston you slide the housing out and the is a oring on the shaft. When that one goes out it will leak air out on the one side... RE: Air coming out of trans beather - marek4792 - 05-25-2017 So is there 3 orings? two on the piston and one on the housing? Unless there's a 4th one? The cylinder housing on mine would not come out of the trans like it is hooked onto the fork? RE: Air coming out of trans beather - Mr Hagg - 05-25-2017 You would be right on yours the housing does not come out. Kind of crazy but the is another oring in there. http://www.inforanger.roadranger.com/index.aspx?search=RTLO16913A&modelID=373&groupID=1417 you will see #6 is the one that will leak. If it was a RTO it would come out but on the one you have you will have to remove the back box. :-( RE: Air coming out of trans beather - marek4792 - 05-25-2017 Yup I managed to get that one then crap I'm stumped. edit: fixed green hose ended up rubbing against the breather housing spliced and put new fitting no more leak RE: Air coming out of trans beather - Mrkentee - 05-25-2017 Wow. I just did this exact thing with the same transmission. Different problem. I couldn't get that housing out, either. I found out why later. RE: Air coming out of trans beather - marek4792 - 05-26-2017 Just out of curiosity can the range housing be modified to be removable without compromising the integrity of the housing or travel of the shaft and fork? |
