| Isx Oil pump - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: ISX Related Help (/forumdisplay.php?fid=68) +--- Thread: Isx Oil pump (/showthread.php?tid=1797) |
Isx Oil pump - Mr Chain - 06-01-2017 I have a 871 recently inframed and the oil pump seems to be making a humming noise any suggestions on what it may be? I'm hoping it's only shims RE: Isx Oil pump - Unilevers - 06-01-2017 probably wrong shim. some had a bad crank gear that had improper clearance in the teeth when it was made. RE: Isx Oil pump - Mr Chain - 06-02-2017 Ok thanks I'll look into re shimming the pump then RE: Isx Oil pump - Signature620 - 06-02-2017 Check the backlash on the upper oil pump gear before you remove it. If the lash is ok then the noise is probably a worn shaft inside the pump. Let me know if you need specs. |
