| Wf 2126 coolant filter with shell red coolant - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: Wf 2126 coolant filter with shell red coolant (/showthread.php?tid=1809) |
Wf 2126 coolant filter with shell red coolant - little john - 06-04-2017 Rawze. I discovered to day that the wrong coolant filter was on my reman engine for the coolant I run. I use red coolant from shell and my engine had wf 2126 filter on it for 25000 miles . I changed filter to wf 2127 no additive today. My question is did the DCA. Chemical in the 2126 filter hurt my red coolant or damage engine. ? RE: Wf 2126 coolant filter with shell red coolant - Rawze - 06-04-2017 (06-04-2017 )little john Wrote: Rawze. I discovered to day that the wrong coolant filter was on my reman engine for the coolant I run. I use red coolant from shell and my engine had wf 2126 filter on it for 25000 miles . I changed filter to wf 2127 no additive today. My question is did the DCA. Chemical in the 2126 filter hurt my red coolant or damage engine. ? Just use a test strip on it and make sure it is ok. Not sure what dca will do to it myself, I have seen others make the same mistake on occasion and it not seem to hurt it. I never leave the coolant in my truck for more than 2 years or 400k miles myself even if it tests good. I am paranoid that way nowadays after the whole waterless coolant debacle of the past that I wish I never did. BTW: you are supposed to be using the WF2127 filter with red coolant.. and not the 2126 that has additives in it. RE: Wf 2126 coolant filter with shell red coolant - little john - 06-04-2017 Thank you. Ya I change coolant every couple years also. This coolant was new with engine last fall. Thank a bunch. RE: Wf 2126 coolant filter with shell red coolant - amermextrucker - 03-25-2023 Can red coolants of different brands be mixed ? I noticed fleetguard coolant says on jug ethylene glycol, local parts store sells Valvoline zerex but it says organic something on it . The fleetguard jug states it can be mixed with most coolants, while the Valvoline product doesn't mention any mixing. RE: Wf 2126 coolant filter with shell red coolant - Rawze - 03-25-2023 (03-25-2023 )amermextrucker Wrote: Can red coolants of different brands be mixed ? I noticed fleetguard coolant says on jug ethylene glycol, local parts store sells Valvoline zerex but it says organic something on it . mixing coolants incorrectly can lead to gumming, and/or liner issues. It is not recommended unless there is a manufacturers statement as to what it is compatible with. Also;;; coolant filter WF2127 should be used with ELC red.. and not the WF2126 water filters. here is some similar posts... http://rawze.com/forums/showthread.php?tid=2131&pid=18365#pid18365 and some info on different types of coolants... http://rawze.com/forums/showthread.php?tid=2518&pid=21642#pid21642 |
