| 2350 high fuel rail pressure - Printable Version +- Rawze.com: Rawze's ISX Technical Discussion and more (http://rawze.com/forums) +-- Forum: Big Truck Technical Discussion... (/forumdisplay.php?fid=1) +--- Forum: Ask Your question... (/forumdisplay.php?fid=45) +--- Thread: 2350 high fuel rail pressure (/showthread.php?tid=1815) |
2350 high fuel rail pressure - Rounded_nut - 06-07-2017 Engine Injector Metering Rail 1 Pressure Data valid but above normal operating range - Least severe level (FMI 15) I got this today, engine runs fine, just serviced a couple weeks ago, is there something I should be looking for or? RE: 2350 high fuel rail pressure - Unilevers - 06-07-2017 air in the fuel! most common cause of the high least severe. check your fuel/water seperator or anything you touched while you serviced it. RE: 2350 high fuel rail pressure - Rounded_nut - 06-07-2017 Huh, ok thanks I'll check it out. |
